Up Topic Welding Industry / General Welding Discussion / T1 welding
- - By Robert C (*) Date 04-15-2007 23:38
I have need info on rod selection, and pre-heat for T1. I need to repair a trailer and due to the liability need to know the proper pre-heat, rod etc... The trailer manufacture does not provide a welding procedure only the material that it is constructed of.
Parent - - By aevald (*****) Date 04-15-2007 23:57
Hello Robert C, awhile back there was a post on the forum here having to do with T-1 materials. If you do a search you will very likely find the thread this was contained in. If you can't find this information, try googling Mittal, they have a document entitled " How to Weld "T-1" Constructional Alloy Steels" it likely has everything you're looking for. Good luck and regards, aevald
Parent - - By Robert C (*) Date 04-16-2007 02:38
Thanks. That was a good article on T-1.
Parent - - By Kix (****) Date 04-16-2007 16:39
What were your search keywords?  I can't find the thread on the t-1 matl.
Parent - By Stephan (***) Date 04-16-2007 17:04
