I have a portable plunger and die machine I designed and built years ago. It has gain considerable weight over the years (or I'm getting older and weaker). I also have a wrap around machine that I designed and built that is very portable. The wrap around machine has several different diameter mandrels for different thickness of materials and it is the machine I am trying to patent. It's light (about 40 pounds total) and capable of bending as thin as 1/16 thick ferrous metals, 1/8 inch thick aluminum, and up to 3/8 thick HY80.
I cut and bend the samples if there is a suitable means of cutting the bend straps on site (by that, I mean shop). I have torch cut straps out of schedule 40, 6 inch pipe and 3/8 inch plate in the field, i.e., construction site, and then ground the straps to remove the HAZ. I don't recommend torch cutting the straps because its a time consuming operation and in general its a pain in the butt. I usually let the welder do the cutting and grinding after giving them the necessary directions. If they screw it up, their problem, start again!
