Up Topic American Welding Society Services / Technical Standards & Publications / How to give a test for round stock to plate.
- - By Kix (****) Date 04-17-2007 13:13
The material is A-514 (t-1) joined to A-1045 round stock.  I'm told you can only get A-1045 in roundstock so how do i qualify a procedure?  Any help is greatly appreciated.  I just need pointed in the right direction.
Thanks,  Kix
Parent - - By castle (*) Date 04-17-2007 19:17
Kix,
What diameter sizes does A-1045 come in?
Parent - - By Kix (****) Date 04-17-2007 20:34
It's coming in as 2 1/4" roundstock. If they can make it in round stock surely they make it in plate also right?
Parent - - By castle (*) Date 04-17-2007 21:45
You could have two plates cut out of one 7" or 8" round bar, but I'm not sure what dia. sizes A-1045 is provided in.
Parent - - By Kix (****) Date 04-18-2007 13:33
I ment if they can mix it up at the BOF and poor it in roundstock molds surely the poor slabs also. AnybodY?
Parent - By Bill M (***) Date 04-20-2007 19:54
You would be better off trying to get engineering approval to qualify the procedure using some kind of a similar group plate material.  (comment:  a plate mill is a bit more complicated than just pouring a cast flat slab, and a rod mill is not just "pour it into a roundstock mold").
Parent - By BillC (**) Date 04-21-2007 16:04
Kix,
You say you are receiving the ASTM A1045 in 2-1/4 rounds?  What specifically does the cert say for the ASTM A1045 material you are receiving?  ASTM-A1045 is Standard Specification for Flexible Poly (Vinyl Chloride) (PVC) Gaskets used in Connection of Water Closets to Sanitary Drainage System...
Here is a link:  http://webstore.ansi.org/ansidocstore/product.asp?sku=ASTM+A1045-05
Regards,
