Up Topic Welding Industry / Technical Discussions / ASTM A-1045 and A-1018
- - By Kix (****) Date 04-18-2007 13:38
I'm suppose to qualify procedures for these 2 material, but i'm told by my go to guy that we can only get it in round stock.  Can you get these materials in 1" plate form?
Parent - - By BillC (**) Date 04-18-2007 19:01
Kix,
I think that somebody is confused ;-)
ASTM A1018 is Standard Specification for Steel, Sheet and Strip, Heavy-Thickness Coils, Hot-Rolled, Carbon, Commercial, Drawing, Structural, High-Strength Low-Alloy, High-Strength Low-Alloy with Improved Formability, and Ultra-High Strength Steel.  Doesn't look like it comes in round bar...
ASTM A1045 is Standard Specification for Flexible Poly (Vinyl Chloride) (PVC) Gaskets used in Connection of Water Closets to Sanitary Drainage System.
Do you really mean AISI/SAE C1018 and C1045 which are plain low carbon steels with .18 and .45 nominal carbon content respectively?
Regards,
Parent - By Kix (****) Date 04-19-2007 20:30
Well the material specs i have call out those #'s on the specific part , but it wouldn't surprise me that someone screwed up around here.
