patpro , pull out the bolts to fly wheel , the thin plate , then twist about 1/4 turn , it will disconnect from dowels , then you need to support the armature so it won't hit the field coils , i use small wood wedges like you use for shim doors with . got to run now i'll check back to-nite . good luck . willie
