Up Topic Welding Industry / General Welding Discussion / bluestar 6000?
- - By monsoon12 (**) Date 04-21-2007 22:36
[deleted]
Parent - - By Molten Metal (**) Date 04-23-2007 00:43
Hello Monsoon12. I believe you are refering to the Miller Bluestar 185/185 DX model.I also own one and have it mounted to a whellbarrow type system for portability.(ued to be mounted on a trailer). I have used it quite a bit now without a ground from that little stud-n-nut thingy,with no problems whatsoever.Its most likly a manufacturer "cover our a$$" thing more than anything.I wouldnt worry about it.
Parent - - By monsoon12 (**) Date 04-23-2007 20:34
[deleted]
Parent - By Molten Metal (**) Date 04-23-2007 21:43
Had it about 2 years.Its great for alot of things.I have a Bobcat 250 mounted on a trailer,but alot of times I need to get into backyards and tight spots and I use the Bluestar. I only run 50' leads on the bobcat and I sometimes cant reach.The 6000 runs up to 5/32 rod no problem.Havent tried anything bigger with it.Duty cycle is just fine for most all your 1/8" applications.100-135 amps. I changed the oil to full synthetic at 75 hours.I made my own lift-eye set up with lead holders that are incorperated into it also.(50' #2). Good luck.
