Up Topic American Welding Society Services / Technical Standards & Publications / FCAW
- - By jaws (*) Date 04-22-2007 18:38
For welder qualification and wps, Is it essential the brand name of wire for welder and wps tests?
Parent - - By waynekoe (**) Date 04-22-2007 19:15
No. Just the AWS classification and specification numbers, such as AWS A5.20 and E71T-8. A listing like this would cover wires from Lincoln (NR 232) and ESAB (Coreshield-8)
Parent - - By jaws (*) Date 04-22-2007 22:08
Thanks for reply but ın table 4.6 item 5 says ''A change in the manufacturer or the manufacturer's brand name or type of
electrode''  for fcaw.
Parent - - By MBSims (****) Date 04-22-2007 22:21
Correct.  But Table 4.6 only applies to procedure qualification, not welder qualification, and it only applies when Charpy V-Notch (CVN) testing of the base metal is required.
Parent - By jaws (*) Date 04-22-2007 22:29
Sims thanks for help thanks I understand it my base material required CVN test. for welder qualification ok I dont have to use same wire.
