Are you referring to Submerged Arc Welding (SAW) ? This process uses a granular flux that needs to be kept dry and stored properly, if it has become contaminated the weld could be compromised. Whether or not you could see this contamination or not viewing an X-ray film really depends on the type of contamination.
