Up Topic Welding Industry / General Welding Discussion / Miller Big20
- - By Robert C (*) Date 05-06-2007 19:17
I just got an 89 big20, and need some help. It runs perfect but will not hold a good arc with a 7018 1/8 unless it is set on the second highest range setting. It has been in storage for a while, and I was wondering if it could have a stuck brush or something like that.
Parent - - By Cole Welding (**) Date 05-06-2007 19:22
it sounds like you need to replace you big blushes on the main part of the gernerator
Parent - - By Robert C (*) Date 05-06-2007 19:41
You say "big brushes" I can only find 2 small brushes.
Parent - - By Cole Welding (**) Date 05-06-2007 20:32
you have found the exiter brushes on the out end  of the generator.  open the door and there should be a cover around the main part of the generator.
Parent - - By Robert C (*) Date 05-06-2007 20:38
This one has an alternator that runs off of the end of the armature. The only brushes I can find run on slip rings.
Parent - - By Cole Welding (**) Date 05-07-2007 02:27
you mayhave to take it to a shop and have it load banked and they can tell you if something is wrong with the generator....  i talked to a friend of mine and he said that the windings might have went bad
Parent - - By Robert C (*) Date 05-08-2007 23:22
I have 72 volts at the weld terminals but I just don't have the current. It welds good but you have to set it one click higher on the range and about 80 on the rheostat to burn a 1/8 7018. It has been sitting a while and I am wondering if it is worth the trouble to clean all the conections from the diodes.
Parent - - By Cole Welding (**) Date 05-08-2007 23:56
that welder just may have to be used. when i went to building rigs last year i used a welder that had ben  sitting off and on sense the 80s and the more i used it the better in welded
Parent - By Robert C (*) Date 05-08-2007 23:58
I did notice a bit of that yesterday. I ran it for 12 hrs on a job just to try it out.
Parent - - By cammarp Date 05-09-2007 00:23 Edited 05-10-2007 01:22
we have a pretty bad environment at work for welders, we blow our welders out about once a quarter to blow our the soot from plasma....  makes a WORLD of difference... if that doesnt do it we even slightly pressure wash them if they are really bad.
Parent - By Robert C (*) Date 05-09-2007 01:25
Thanks I will try that. Do you think it would be worth sanding all the conections anyway.
Parent - - By gawelder (**) Date 05-09-2007 01:54
Robert, I have a Bobcat 225 that I haul on a trailer.On this machine there is a chassis ground that get's frayed and it will get weak. Also you might could replace the ground clamp.
        Just my 2cents worth!
        gawelder
Parent - By Robert C (*) Date 05-09-2007 02:11
Where are you at in GA. Gainesville here.
Parent - By makeithot (***) Date 05-09-2007 14:40
You may need to check the armature windings for over heating The older machines had a bad habit of burning out when the duty cycle was exceeded. One of the reasons miller machines have such a bad rap in the oil patch.
