Up Topic Welding Industry / General Welding Discussion / Welding Of Piping A 312 TP 347 H
- - By Mudassar Naveed Date 05-11-2007 05:30
We are in the phase of welding our ammonia converter out let piping, material is A - 312 TP 347 H, design Pressure   183.1 Kg/cm2   Temprature 425 degree Centigrade. We have bare wire ER 347 for carrying out its root and for filling & Caping we are available with E - 347 instead of E - 16 - 8 - 2 - 15, what you suggest can we complete this welding with the available electrodes.
Please suggest at the earliest.
Regards,
Mudassar Naveed
Sr Staff Engr - Mechanical
Parent - By js55 (*****) Date 05-11-2007 13:28
16-8-2 is used commonly as a substitute for 347 for high temp applications, but it is just that-a substitute. There is no reason that I can think of that 347 filler wouldn't be acceptable for the service intended of a 347 base material, except that the Molybdenum in 16-8-2 is considsered to improve the creep rupture ductuility of CrNi SS's. The main problem however with 347, of course, is mircofissuring. 347 is actually quite sensitive.
Keep in mind, if you decide upon 16-8-2, that the ferrite will most likely prove to be quite low, if you test it. Its OK. Even with  low ferrite this stuff is remarkably crack resistant.
But the decision needs to be engineered. How important is the reduced high temp creep ductility of 347? How much restraint is there upon the weld joint-which woul dindicate that perhaps 16-8-2 is the better choice? What are the varying costs of eachof the fillers in your area-And should this be compared with the possbility of repairs should oyu discover microfissures int eh 347? Perhaps a review of service history of the part is in order.
