Up Topic Welding Industry / Technical Discussions / Heat Input
- - By BOON 2 Date 05-12-2007 09:28
In one of our project, a client had commented that heat input was not addressed in WPS (ASME code) sumitted.
I would like to know more on heat input during welding.
1) Can someone advise what is the formula use to caculate the heat input.
2) On the WPS, which section should the heat input be placed. QW-409?
3) How does the value of heat input affect welded joints.
4) Is there a recommended range for heat input when welding with GTAW process on stainless steel?
Regards,
Boon
Parent - - By Eutectic (**) Date 05-12-2007 13:15
BOON 2
Here is one of many previous posts regarding your questions
http://www.aws.org/cgi-bin/mwf/topic_show.pl?pid=52389;hl=Heat%20Input#pid52389
I would recommend searching Heat Input in the forum, there are a myriad of topics with answers to your questions and a lot more.
Cheers
Parent - By js55 (*****) Date 05-14-2007 14:36
Eutectic is right. There is so much being asked in your post that a search of the site would do well to answer many of your questions. Then you could return with more specificity.
