Up Topic American Welding Society Services / Technical Standards & Publications / Renewal of Previous Qualification D1.1 2006
- - By pipewelder_1999 (****) Date 05-15-2007 22:52
In D1.1 2006 Para 4.32.1.3 it is indicated that "Welders have the option of using a test thickness of 3/8 in. to qualifiy any production welding thickness greater than or equal to 1/8".
The statement and the rest of the paragraph make no reference previously qualified processes, positions etc. I am having a hard time understanding what the paragraph means. I could take it to mean regardless of what I was qualified at before, taking a test on 3/8" plate will qualify me to weld on ANY thickness.
The similar statement in ASME Sec IX is pretty clear to me but this one is a stumper. We have a guy returning to work tomorrow that I am going to be testing.
Thanks
Gerald
Parent - - By jwright650 (*****) Date 05-16-2007 11:21
Hi Gerald,
C4.1.3.1 gives a little insight to the paragraph 4.32.1.3. (Also see Paragraph 4.1.3.1 where it originally references  paragraph 4.32.1)
Basically if the period of effectiveness has lasped, you could re-instate the welder's qualification if the welder passes the same test on 3/8" material vs making the welder test again on 1" material....at least that is what I get out of reading that...
Parent - By Mwccwi (***) Date 05-16-2007 16:03
Mr. Wright, I hope your right because this is the same interpretation I've been using fo several years now, luckily I've used this only twice in the last four years.
Parent - By pipewelder_1999 (****) Date 05-16-2007 19:11
So basically there is no advantage with this paragraph unless the original qualification was done on material greater than 3/8".
