Lloyd,
FCAW TIG wire, strictly in my opinon, should be used as a last resort. Corrosion test have shown that it produces "less than desirable" results. It is just hard to replace an inert gas as the shielding with a flux coated TIG wire. I, personally, have found that Solar Flux to be equally, or better, in most circumstances. I guess the circumstances dictate the use of any welding process, though. Again, this is my opinion.
