Dear all,
When I am going to use AWS D1.1 standard for Ultrasonic Testing, usually my reference standard is the 1.5 diameter hole/15mm depth from IIW block @ 52db 80%FSH, But when I am also going to construct DAC Curve based on the ASME Section V&VIII,using ASME reference block(thickness=19mm & 2mm diameter hole @ 5mm depth) @ 42db 80%FSH for 1st reference Peak and so forth.
My Question is why that AWSD1.1 has greater reference dB since it is only use for structural compare to ASMEVIII that it is being use in more complicated products?
