Up Topic Welding Industry / Inspection & Qualification / Step Block Protection
- - By fbrieden (***) Date 05-18-2007 16:56
Suggestions for protecting calibration step blocks from corrosion, after handling, needed here. Thanks in advance.
Parent - By CHGuilford (****) Date 05-18-2007 17:09
I use a clean rag, lightly sprayed with WD-40, to wrap my gage blocks in.  Then I put them into a zip lock freezer bag.  So far that seems to work pretty well.
Parent - - By jwright650 (*****) Date 05-18-2007 17:19
Fran,
I thought they were nickle plated so they won't rust. Mine have never rusted after all of these years. I just wipe off the couplant with a soft rag and put them back away, so far they haven't rusted.(wait, the couplant I use does have some anti rust stuff in it)Exosen 30
Chet's idea should work fine or a light coat of vaseline smeared on them...
Parent - By fbrieden (***) Date 05-18-2007 18:03
That must by why they shine so much. I'll use your suggestion, as well as Chet's.
Parent - By drifter57 (**) Date 05-18-2007 17:40
DoAll makes a good gage block preservative they are out of Chicago
