Pang,
both E-7018 (low hydrogen) and E-6013 (rutylic) are low penetration electrodes, and this is their main disadvantage.
Back in my days of erector engineer (along my life I've been an erector first, a project engineer after and a college professor nowadays that I'm retired and old), well, back in my days of erector engineer,as I was saying, the root pass in a carbon steel piping was given with E-6010 (or E-7010) for good penetration, and subsequent passes with E-7018.
E-6012 and 13 were used for platework not subjected to pressure or high temperatures. Example: the casing of a boiler, i.e., the platework that "wraps" the boiler furnace to keep a small positive pressure in pressurized boilers, was welded with those electrodes.
As between the waterwalls and the casing there's the refractory lining, the casing temperature is around 120 - 150 Celsius (you translate into Farenheit), a temperature that E-6013 withstands perfectly.
