Up Topic American Welding Society Services / AWS Learning & Education / Prequalifed CJP Groove Welded Joints
- - By whip (*) Date 05-21-2007 02:32
Question in third column(Base Metal Thickness) It has "T1" and "T2" Could somebody break down and explain what they stand for and mean in this PREQUALIFIED WPS.
B-U2
B-L2aS                                                   Thanks Guys
Parent - By MBSims (****) Date 05-21-2007 03:39
From Figure 3.4 in AWS D1.1, T1 is thickness of material on one side of the weld joint, T2 is the thickness of material on the other side.  For these 2 joint types, the figure only illustrates T1.  I assume the "-" in the column for T2 means that the thickness must be the same for both sides and can't be an unequal thickness weld joint.
