The major material manufacturer's usually provide "typical" data for their product. It's not as simple as having it all in one spot, but with a little patience, you can compile the data on your own.
Alternatively, ASME Section IIC has all the required specifications, but it's a relatively pricey book that you may not want to purchase.
Charles.
Hello Kix, I tried to find some info on the web in regards to your question and apparently I just don't know how to navigate it properly because I couldn't find what I have in hard copy. The ESAB Filler Metals Data book has what you're looking for and the Hobart Pocket Welding Guide does also, I believe. So if you have access to one or both of these, take a look in them. Good luck and regards, aevald
