Hi, I'm new member of this forum. I'd like to raise a question regarding the welder position qualified. Actually, this is related to 6GR qualification range. Based on the AWS D.1 Ed 2006 Table 4.10, 6GR position welder will qualified for all position with certain notes in the table.
If we have some joints which is CJP joint between plate to tubular connection (2G) having groove angles greater than 30 Deg, is it possible to utilize the 6GR welder to weld this joint? can we consider the joint as T joint?
What is the explanation of "backing" in the note (d) table 4.10, is it related to backing plate or backing weld?
What is the definition of T,K,Y joint on the structural and mock up joints? is T,K,Y joints always identical to tubular joints how about the other joints? Thanks for the response.
