in comparison to the cladding the checking is more significant in the stoody the cladding is three layers, 1/4" mild steel plate /with a 309 type of cnc welded cladding/ then the chrom carbide. have you had procedures developed that dont include such a high pre heat?
this is for a new digester for the tar sands . they steam inject a slurry while it is churning/rotating in a large funnel and then the oil and sand are separated. something similar to a cream separator. we built proto type and now that is a proven technology we are building the large process type ,very expensive/innovative project
i am looking to arm myself for victory in regards to this project, i am a firm believer that information is a force and an overwhelming force applied to any situation yields the greatest possibility of success. i am very competitive and see the opportunity/challenge of a project as an opportunity to compete against myself, which means a majority of the time i am the winner.
i am still trying to figure out if im the only competitor in such a situation sometimes i still seem to come in second.
again the reason why i am arming myself with information
thanks for your input so far and look forward to any other information you might be willing to share
thanks
darren
p.s.will try to get some pics of the welding profiles and wps for posting so as to add some clarity
just looked at your occupation, man am i glad you responded, look forward to any help. last time we put on around 50 boxes of stoody 33 and this project is around 10 times more welding at least. last time we had a hard time sourcing the rod if there are any concerns this time ill post them
again thanks
darren
If you will post some pics, I will do my best to help you. I'm not familiar with a 309/Cr-C clad plate, but I certainly don't know everything LOL!!
I have some experience with chromium overlay plate. The manufacturer recommends for joining purposes that the root (from the carbon side) be welded with a 309 electrode in case the chromium overlay is contacted. This will prohibit any cracking issues that would be created by welding with a mild steel electrode. After the root pass has been made the balance is then welded out with mild steel which will readily join the 309. I normally run a pass of hard surfacing material on the inside of the join to cover where the overlay plate meets. We have had great success welding overlay plate in this manner. I am not sure what the preheat is all about as we have never used a preheat and there were no recommendations by the manufacturer for preheat.
