Before I get a electrician I need some more info on the right wiring for a Solar 165 ( 208/230 ). I have 100amp service and I dont own the house so cheaper is better. My garage is 100' from the house. It has a sub panel along and I have a greenhouse that has a sub panel. Needless to say my 100 amp main panel is pretty full. Idealy I would like to run 220 to the garage but I was thinking of having a heavy extension cord made to run off the dryer hook up. I usually weld in the middle of my driveway so the extension cord would be 50' which I already have. Its a heavy heavy 220 extension cord. I was hoping to have it rewired to work this way but isnt my dryer 240 not 220?
Where can I get more info on this solar 165 welder? The info on the unit is
PRI Volts 208/230, Pri Amp 13.6/12, 10, 60 Hz, KVA 4.0, SecVolts 20, Sec Amps 100, Duty Cycle 20%, Max OCV 29
Thanks
