First of all, if you do'nt have any experience installing electrical equipment, then find someone that does!!! If you do have experience then look around the power source... There should be a plate with all of the info you need either in front of the power source or behind next to the primary input cable... Do you know whether or not this is a single phase or 3 phase power source or both??? Anywho, the plate should tell you how many amps the power source draws in.
If you're using a 240VAC step up transformer and the power source is set via jumper links inside to 208VAC you might mess up the insides if you get my meaning so make sure that you've got all of your ducks in a row! If you do'nt know what I'm talking about - then get someone that DOES to install everything properly with a primary emphasis on safety!!!
