My wire feed only works when I push the wire advance button on the welder. I can "weld" with the handle button pushed if I also hold the wire advance button on the welder down. My problem is the wire wont advance with the gun button only the button on the welder. Whats funny is it worked 2 days ago hooked up to 120 but when I went to 220 it stopped working. I was testing the unit to see if everything worked with a 120 line. The welder is a solar 165 208/230v from 1982 with no jumper that I can find. In between I had the gun apart to get a tip and nozzle. There are two wires in the gun. When I push the button they test fine all the way to a harness plug before the wire feed motor and a circuit board.
I was hoping for some ideas before I pull the circuit board and start testing that along with chasing every wire in this circuit with my ohm meter. I dont see anything noticable as far as melted circuits or anything
Thanks
