Up Topic American Welding Society Services / Certifications / AWS D1.5 Question
- - By - Date 05-17-2000 17:59
I am currently setting up a test to qualify welders under this code. I am using A709 grade 36 1" plate. I need to use a backing strip for the test and I want to know whether or not I can use A36 material for the back up since it is identical to A709 grade 36. The reason I ask this is because I would have to order 2.5 tons of 1"x 3/8" bar in order to get it (due to mill order requirements). Any information would be appreciated.
Parent - By CHGuilford (****) Date 05-30-2000 16:26
You shouldn't have a problem using the A36 backing bar provided that 1) your client/customer does not take exception to the substitution, and 2) you have CMTRs that will show your material meets all requirements of A709 Gr 36.
