Hello draggbody, it is likely that this spindle is not cast iron, but cast steel instead. Likely not a good idea to cut and weld on this component even if it is cast steel and technically could be welded. You will end up opening yourself up to a host of liability issues that you don't want to be a part of. It's one thing to do this on something that you will be using for yourself and quite another to be selling this as a product to the general public. Just my $.02 Regards, aevald
Well, i work in a place (and country), where repairing of unadvisable, impossible , unlikely etc, components of every metal you can think of,
is an everyday thing, (because is very far and spare parts are not readily found). I´m a welding engineer in charge of very skilled welders
(some of them have the forementioned "oxyflame cast iron rod Technique", not used very much now because the rods are now not produced because of
the popularity of SMAW ENi-CI and ENiFe-CI electrodes).
Welding cast iron can be quite succesful, if proper techniques are used. Main problems are
- Hardening of HAZ, because of dilution of carbon into the probably already high carbon matrix of the cast iron, leading to martensitic and/or white
iron formation upon cooling in the zone (brittle, low ductility phases). This also can lead to cracking because of dilatation/contaction of the weld.
- Because of the nature of the structure, usually cast iron pieces absorbs lots of oil or water, leading to porosity problems in the weld or HAZ
- Random nature of the composition of the cast iron, some of them have lot of deleterius elements to welding (sulphur, phosporous, Sn, etc.)
Hardening of the HAZ can be minimized by either weld with very high preheat and very slow cooling to prevent "quenching" of the HAZ, plus
post weld heat treatment to eliminate any formed martensite
, or, the complete opposite, weld very cold, no preheat, low diameter electrodes, short straight passes, to make this "brittle HAZ", very thin.
in both cases peening of the weld when is hot is advisable
Other two problems can be minimized by cleaning, or burning impurities and pre "analysis", (chemical and metallographic"), of the iron.
But even we recognize that , when a failure in the weld will almost ceirtanly lead to personal injury or loss, that repair or work should not be done,
as in the case you post. Nobody in the world can assure you a 100% safe repair on cast iron, and if somebody do it, he is lying, i'm very certain
of that
