I read a similar article on this (draggbody and I are friends) while researching this, the pin he is referring to is basically a machined rod with a threaded end for a castle nut, on this pin, you install the rotor with the bearings inside. Hope that clears up a little bit. It looks like he's using a migwelder, his welding looks good and solid, its just a question as far as the science behind welding these two metals together and the safety issue it creates.
