What is the alloy, the thickness, joint configuration? Measure the primary voltage at the fuse box, the outlet, at the terminals of the primary connections on the terminal board in the machine. Pretty close to the same values - fantastic. Excellent choice for shielding gas although he and he mixes are harder to get the arc started especially on thin materials at low amperages. Set the machine's ac balance control at maximum penetration and sharpen the 2% ceriated/thoriated tungsten to a point.
