Up Topic Welders and Inspectors / Welding Equipment Classifieds / Millers
- - By TRC (***) Date 06-04-2007 21:29
Miller 330ABP, low hours, works great $500, this is a single phase only that can run on 200,230,460 volt. For you younger welders the 330 ABP is an AC/DC TIG/ stick machine that has great low end performance( through approx 210 amps) for AC GTAW. DC GTAW is goood through the entire range of the machine. DC SMAW is also a very good performer even with 6010. No torch or cooler is included.
Miller ShopMaster 300, AC/DC/CV, low hours, $550, this is an older Shopmaster 300 from the early 90's single phase only 200,230,460 volt, it does not have balance control that the newer ones have. It does include a Lincoln Hi-Freq unit to do AC/GTAW, DC/GTAW, can also run wire, no feeder included.
Miller CP300 3 PHASE ONLY!!!!! $ 750. This one belonged to a little old lady from Pasadena!@#$%^ just kidding men (and ladies). It does also have very low hours-no kidding. Again for you younger welders this was one kick butt machine in it's day and still is in use in many shops. This one has a Spoolmatic one pound spoolgun for GMAW aluminum and can also run any other wire that requires up to 300 amps. I used it running .062 E71T1 on rollers doing API1104 and never had a repair.
These fine machines are located in southeast Pennsylvania, in the York area.
Parent - - By 420fitter Date 07-02-2007 21:31
Just wondering if they are still available?
Parent - - By TRC (***) Date 07-03-2007 21:25 Edited 07-18-2007 21:22
Hey 420, yes they are.
Parent - - By jab Date 07-04-2007 01:18
hi, do you have a spoolmatic 30A?
Parent - - By TRC (***) Date 07-05-2007 23:03
Hey jab, no it's the old Spoolmatic 1 or 2
Parent - By Johnnyairtime Date 04-17-2008 16:15
I'm looking for a Spoolmatic 1 (or 4 pin) for my Millermatic 200.
Will you seperate the gun from the welder and sell seperately??
VERY interested.
Email - johnnyairtime (@) gmail (DOT) com
(sorry about the email address. But it's to save me from spammers)
Thanks!!
Johnny
Parent - - By paul anderson Date 09-14-2007 04:53
STILL HAVE THE A/BP AND THE SHOPMASTER?
Parent - By TRC (***) Date 09-15-2007 23:10
Hey Paul, still have the Abp
