Hello dnewman417, it is likely that you haven't got the machine controls set correctly. Instead of having the machine amperage control set to remote, you've probably got it set on panel thus when you depress the pedal, instead of starting out on the low end of the amperage setting and having adjustability you only have what the amperage is set to on the machine setting(just a hunch). Regards, aevald
