Up Topic Welding Industry / General Welding Discussion / 201 SS
- - By 877412 (*) Date 06-06-2007 05:30
Are considering using 201SS instead of 304SS for the fabrication of miscellaneous boxes attached to trucks. Cost is the reason. Are there any fabrication/ welding/ polishing considerations. I know that 201SS is alittle stronger THAT 304ss  as the yield is higher so the enlongation is less consequently the fabrication ( bending ) might be slightly different. How about the welding? Seems 308 filler is still recommended. Any hot cracking or other issues with this change that anybody is aware of?
Parent - By chuck meadows (***) Date 06-06-2007 13:05
Look in the "Technical" section and about 3/4 of the way dow on that page, 201 is discussed.
