Thank you for your information.
I have taken on new responsibilties relating to welding, inspection etc. for the past few months. With self study, I realise that the coverage for welding is very wide and much to learn.
Checking through the material grouping in QW/QB-422, could not find listing for AISI 904L materials. Is this an uncommon grade and where can we find these materials in actual applications.
Boon
In QW/QB-422 Nonferrous P-Numbers and S-Numbers, it is listed as Spec. No. SB-625, and UNS No. N08904.
Chuck
904L is actually quite common, having been around awhile. Though I believe not as common as it used to be simply because newer alloys have infringed upon its traditional applications. The weld procedures are well developed.
It was originally developed for reducing acids, specifically sulphuric, hence the high nickel content.
