Up Topic American Welding Society Services / Certifications / do i have enough
- - By tbigtdav (*) Date 06-13-2007 23:53
ok im interested in the cwi and after guidance from some people this is the material i have to study with..........first i have the certification manual for welding inspectors(cm2000)and ii also have all the material including part b of the test from the 2 week cwi prepatory class from aws including practice questions and excercises with answers..........do i have enough material to study successfully and if not can anyone suggest any other material .................thanx
Parent - - By new tito (***) Date 06-14-2007 01:32
So you have all of the material that they give out at the seminars?
Did you get a copy of the code you will be testing to?
If yes to both of the above, you should be good to go.
Parent - By hogan (****) Date 06-15-2007 18:06
aws a2.4 if your not up on your symbols
