I don't know what the final application is for the SS to Al tube connection, but flame spray is not normally used for build up that would have structural strength. With flame spray, the deposit may not even be leak tight, as pores between the "splats" can have a leak path to the base. Probably more info on the end purpose of the joint would help.
