Up Topic Welders and Inspectors / Welding Equipment Classifieds / Portable CNC Cutting Machine Makes CNC Cutter Affordable
- By denniswang Date 06-22-2007 04:15
Portable CNC Cutting Machine Makes CNC Cutter Affordable for Medium and Small Enterprises
ESS Ltd., an innovative China-based supplier of cutting equipments, has launched to the global market a mile-stone Portable CNC cutter which is affordable for all small and medium enterprises.  The company already has a great success in its domestic market in this business and is looking for the global market.
Looks somehow like a semi-automatic cutting trolley but with a cross beam on its central unit moving on the x-axis, the portable cnc cutting machine is a wonderful mixture of a simple machine with cnc profile cutting features.
Before SteelTailor is in the market, enterprises have to pay tens of thousands of dollars for a gantry or bench type cnc cutting machine.  It is a heavy investment for a small business. Also it is a waste for the CNC cutting machine owners to cut small parts with a big cutting machine.
It is not only the high cost that restricted the application of gantry and bench CNC cutting machines.  These types of big CNC cutting machines are fixed in a workshop and it takes much space.  In many applications, the cutting operation needed to be carried out at the site where the steel plates are stored. It is nearly impossible to move a big gantry or bench CNC cutting machine from one location to another only for a temporary task. What is to be moved is only the metal sheets.
Apart from the big CNC cutting machines, the small profiles are cut by conventional profile cutters such as pantographic cutters. Some blanking is made by straight line cutters or trolley cutter as they are called in some countries.
SteelTailor P solved all the problems. It is a small CNC profile cutter and low cost.
http://www.steeltailor.com
