Hogan
There is an explanation of how to use the type 1 and type 2 instruments In SSPC PA-2. However, since I do not have more details about your painting requirement, the contract requirements, and the type instrument you are using, I couldn't give you anything definitive.
I am influenced by a problem that is rather timely with your question. I am inspecting the painting on some of the he World Trade Center Transportation hub steel. The Painting Contractor had to place a 2 to 3 mil blast profile and then coat 3 to 5 mils of Carboline 859. When I checked his blast profile, I noted that he had 5.6 Mils when merasured with an Elcometer 224 Electronic Profile Meter. The contractor was using the Testex X-Coarse Tape and showed 3,6 Mils. So, the Client / Owner agreed to use the Testex Tape profile readings. The contractor called Carboline Technical, and was told that he had to add three mils over whatever readings he had above 3.0 Mils. Thus, the painting contractor had to place 6.6 Mills of paint to get the minimum 3 Mils of coverage.
Now. this contractor can achieve a 2 to 3 Mil profile, he just has to use lighter shot/grit combination. He dosen't want to do that, because it would double or tripple the time it took him to blast the beams. What he didn't know, was the effect that going over the maximum recommented blast Milage would have on the paint thickness requirements.
Both the contractor and I (as the third party inspector),have Type 2 DFT gages. With the Positector 6000, I zero it on the bare blasted substrate, then adjust it on a 6 Mill plastic shim. I also have an Elcometer 345, ( 9 button) Type 2 DFT gage. With that instrument, I use a 5 Mil shim on the blasted substrate and then a 10 Mil shim. This assures accurracy within a certain range.
If you go on the www.ktagage.com web site and look in their catalog, there is a book about using paint testing gages. It costs about 80 dollars. The SSPC- PA2 costs about $20.00.
If you want to Send a private message, and give me your phoine number. I can call you tonight.
Joe Kane
