Up Topic Welding Industry / Technical Discussions / Welding a 2" tube 316 L to a hastelloy flange C22.
- - By thesmiths1969 (*) Date 07-06-2007 12:40
What is the best consumable to use when welding a C22 Flange to a 316L Tube and where would I get this info for future reference.
Cheers Andy
Parent - By Lawrence (*****) Date 07-06-2007 13:30
http://www.haynesintl.com/pdf/h2019.pdf
and
Detailed fabricating information for C-22 alloy is available in the booklet, Fabrication of
HASTELLOY® Corrosion-Resistant Alloys (H-2010) and C-22® Alloy Welding Information
(H-2066).
http://www.haynesintl.com/pdf/h2010.pdf
Parent - - By MBSims (****) Date 07-06-2007 20:24
The ERNiCrMo-10, which is the matching filler for C22 to C22, can also be used to weld C22 to 316L.  There are other nickel alloy filler that would be alternates, such as ERNiCrMo-4.  The 300 series stainless fillers would not be recommended.
Parent - By CWI555 (*****) Date 07-07-2007 01:49
I think I would go with the NiCrMo-4 if welding C22 to a 300 series. I've qualified that combination with some success in the past.
