No, it is an automotive application. Wheel studs are 7/16 press in studs presently at the rear axles and 12mm at the front hubs, and both will be drilled out to accept 1/2" x 20 x 3" long press in studs. I found a 1/2" stud that has a smaller knurl(.564"), so I won't have so much material to take out.
