Up Topic Welding Industry / General Welding Discussion / big40 and 251 miller
- - By Sourdough (****) Date 07-12-2007 18:34
What are they worth? less than 500 hrs each??????????????
Parent - - By 357max (***) Date 07-12-2007 18:39
The distributor says 11-14 grand for the Big 40 depending on year, model & options
Parent - - By Sourdough (****) Date 07-12-2007 18:41 Edited 07-12-2007 18:44
Well......the big 40 is a 93, and the 251 is a 97, but the guy is a shyster - see where Im going?
2600 for the both.......You know you're all jealous!!!
homeboy is wanted by the irs -teehee
Parent - By 357max (***) Date 07-12-2007 18:45
For that rocket deal you can buy a lot of parts & pieces and still be dollars ahead.
Parent - - By billvanderhoof (****) Date 07-13-2007 02:39
Make sure the title is good, could be stolen for that price.
Bill
Parent - - By Sourdough (****) Date 07-13-2007 15:22
already ran the numbers
Parent - By makeithot (***) Date 07-15-2007 22:01
SD, I'd  have to say you  are getting a real good deal for the money as long as they arn't hot. I run a Big40 deluxe bought last year bottom line on the machine after taxes not including spool guns, suit case etc.  Was $13900.00 with cat deisel. Check the arc stability as there are some that don't follow duty cycles while gaugeing. This is the second big40 I've owned and always been happy with there performance.
