Up Topic Welding Industry / Technical Discussions / ASME and API
- - By sabir (*) Date 07-15-2007 04:01
How can we relate ASME 31.4 and API SP 1104...? And what is this SP stands for
Thank you
Sabir
Parent - - By ssbn727 (*****) Date 07-15-2007 06:23 Edited 07-15-2007 06:42
Here's ASME B31.4:
B31.4 - 2002 - Pipeline Transportation Systems for Liquid Hydrocarbons and Other Liquids
This Code prescribes requirements for the design, materials, construction, assembly, inspection, and testing of piping transporting liquids such as crude oil, condensate, natural gasoline, natural gas liquids, liquefied petroleum gas, carbon dioxide, liquid alcohol, liquid anhydrous ammonia and liquid petroleum products between producers' lease facilities, tank farms, natural gas processing plants, refineries, stations, ammonia plants, terminals (marine, rail and truck) and other delivery and receiving points.
Piping consists of pipe, flanges, bolting, gaskets, valves, relief devices, fittings and the pressure containing parts of other piping components. It also includes hangers and supports, and other equipment items necessary to prevent overstressing the pressure containing parts. It does not include support structures such as frames of buildings, buildings stanchions or foundations
Requirements for offshore pipelines are found in Chapter IX. Also included within the scope of this Code are:
    * (A) Primary and associated auxiliary liquid petroleum and liquid anhydrous ammonia piping at pipeline terminals (marine, rail and truck), tank farms, pump stations, pressure reducing stations and metering stations, including scraper traps, strainers, and prover loop;
    * (B) Storage and working tanks including pipe-type storage fabricated from pipe and fittings, and piping interconnecting these facilities;
    * (C) Liquid petroleum and liquid anhydrous ammonia piping located on property which has been set aside for such piping within petroleum refinery, natural gasoline, gas processing, ammonia, and bulk plants;
    * (D) Those aspects of operation and maintenance of liquid pipeline systems relating to the safety and protection of the general public, operating company personnel, environment, property and the piping systems.
API 1004 covers welding and inspection of Pipelines and related facilities... In other words as verbatim from the catalog: " Covers the gas and arc welding of butt, fillet, and socket welds in carbon and low alloy steel piping used in the compression, pumping, and transmission of crude petroleum, petro-products, fuel gases, carbon Dioxide, nitrogen and, where applicable, covers welding on distribution systems.
It applies to both new construction and in-service welding.
This Standard also covers the procedures for radiographic, magnetic particle, liquid penetrant, and ultrasonic testing, as well as the acceptance standards to be applied to production welds tested to destruction or inspected by radiographic, magnetic particle, liquid penetrant, ultrasonic and visual testing methods." pages: 68 total.
Here's the American Petroleum Institute's 2007 catalog and if you look at page 55 in the .pdf, you'll notice that API 1104 is listed as "std 1104" not SP as you alluded to. Now someone may use SP as an abbreviation for: "Standard Practice or Publication" but, officially it does'nt refer to anything in the catalog... Here's the API 2007 catalog in .pdf format:
http://api-ep.api.org/Publications/upload/2007CatalogWEB-3.pdf
Here's the homepage for the American Petroleum Institute:
Parent - By sabir (*) Date 07-15-2007 09:21
Thanx Mr. Henry....
