There's not really a hard answer in AWS.
Section 5.8 says to follow the producer's recomendations. For example, the Mittal T-1 sheet in front of me reads no more than 400 deg. F. for 514 up to 1-1/2" or 450 deg. F. for 514 greater than 1-1/2". Table 3.2 lists the maximum interpass temperature for a couple materials in the footnotes. Table 4.5 limits maximum interpass for GTAW based on the maximum interpass temp. recorded during qualification. If CVN's are required then you're also restricted to the maximum heat input you qualified with by Table 4.6.
