What is the typical procedure for completing a prequalified B-U3c-S in conformance with AWS?
More specifically:
Are both sides of the joint typically beveled prior to any welding?
Or, can you bevel one side, then weld it, and then flame cut the bevel on the other side?
Is there a section in D1.1 or D1.5 that would clarify which procedure is acceptable?
