I've been having problems trying to understand welding alum.When I get done with the root pass and look at it man it looks terrible.It's about1/4" wide but it looks like it has a crack in it.When I grind it out to make it flush there is no evidence of a crack .I'm using TIG process open-but.Mostly on sch10 but sometimessch40.I've tried to gap it 16th and add rod and tried to fuse it both processes I have to add rod.The root is there but it is thick and the indent in the middle any help I would be very thankful R
