We have a very large weldment that is 5.5" thick with branch connections. Considering that it will be in a corrosive environment, we are looking to do as much stress relief as possible. In the end the right thing to do is to do a solution anneal at 1950 with a fast cool. The biggest issue is the fast cool due to the fact that this weldment is so large. Normally they used a 1675F stress relief which seems to be right around the sensitization range. The reason I was asking about a low temp stress relief is because we were looking to avoid the sensitization range. Does anyone know what the cooling rate I need to use through the sensitization range??
I need to make a correction of my own statement. I got to thinking about it and went back a did review of the November 86 WRC Bulletin, wherein it states that Creq/Nieq ratio < 1.48 will solidify austenitic-ferritic, between 1.48 and 1.95 will solidify ferritic-austenitic, and > 1.95 it will solidify single phase ferritic. Now, these exact numbers I'm sure will vary depending upon how you define Creq and Nieq. But I think the general scheme probably still holds.
But in any case, we are not talking about a full single phase transformation, we are talking about a partial transformation from mixed solidification modes.
Keep in mind,this is base metal stuff, not weld metal or even HAZ's, where the cooling rates change the rules.
Therefore, 304 SS will solidify as a mixed mode. The volume percent being based upon the Ni/Cr eq . Clearly the higher the Nieq the higher the austenitic solidification volume percent and vice versa. However, at room temperature it will be fully autenitic, or at least with only residual amounts of ferrite present. I apologize for my mistatement.
But now I have to ask, why didn't some of you jump on this? :>) Tsk, tsk.
