bigskyguy,it is confusion it took me a while to get a grasp on it , but this is my interpretation. 4.2.4 reads that all welds shall be (classified) as (F),(H),(V),(OH). On a WPS it states position of groove or fillet,figure 4.1 gives you the positions for each position,say the wps states that the position it will allow you to weld in is 2G,or the wlder is only qualified in 2G,if the axis of the weldement is 0 to 15 degrees and the weld was between 210 to 280 and 80 to 150 degrees of the rotation of the face you are within the 2G range,but if you were to weld 0 to 80 or 360 to 280 degrees with the weldement in the same plane then you would be welding over head. You are correct on axis limit C, 0 to 80 is a large range for overhead , as long as you weld 0 to 80 and 280 to 360 degrees of the face then you are welding in the 4G position. Look at the vertical D it also has a large range , if the axis is 15 to 80 degrees and the weld is 80 to 260 degreesof the face it is a vertical weld ,if you go past 15 degrees on the axis and the weld is 150 to 210 of the face then its a flat weld. Then 4.2.4 says test ass. positions are shown in 4.3 , 4.4 , 4.5 , 4.6. ASME does give you an axis limit as for D1.1 the only on i know of is for pipe or tubing. When i give a plate groove test if its vertical then the plate is in the vertical position , if horizontal then the plate is in the horizontal position. I dont know if this helps , but i hope so
