Up Topic Welding Industry / Inspection & Qualification / Bolt Holes
- - By strat (**) Date 07-29-2007 20:34
Does it state in AWS D1.1 the shortest distance between c/l of hole and end of beam, say you had a W8 by 35 with 13/16" holes at the end of beam,what is the shortest allowable distance.If it does not state in AWS D1.1 then were could i find it. Any replys would be helpful
Parent - - By MBSims (****) Date 07-29-2007 22:19
For structural steel buldings, see AISC LRFD Specification Table J3.4.
http://www.aisc.org/ContentManagement/ContentDisplay.cfm?ContentID=21636
Parent - - By bmaas1 (***) Date 07-30-2007 18:39
It is usually 1 1/2 times the bolt diameter for end distance.
Brian
Parent - By strat (**) Date 07-30-2007 22:12
Thanks for the reply's
