Ti,
The referencing document will dictate what type(s) of mechanical or nondestructive testing your weld requires. Choosing which axis to bend your specimens is not usually an option. My experience during performance qualifications is that most welders try to run as hot as possible to reduce any chance of busting out (failing).
Aluminum is very sensitive to heat input when it has been aged, treated, etc. (even though these alloys are non-heat treatable-oops.) Many welders I have tested bust out on the tensiles and/or bends due to the relatively high heat input with any given process. Not because of IJP/IF or inclusions.
I did not have this problem when I worked as a welder in the aerospace industry because I have a tendency to weld "cold". I have been told this by several welding or metallurgical engineers over the years.
If you can get a hold of someone at Alcotec, they are very (VERY) knowledgeable on the subject of aluminum welding and give excellent seminars on the subject as well. Give them a call and let me know how you do on Thursday.
Alcotec (800) 228-0750 (US and Canada)
Good Luck!
