I am working on a small metal cabinet, brazing along a seam to fill gaps and improve appearance, having trouble making the work flow as well as it should, using a small bronze flux coated rod w oxy/acet the work surface is grinded and clean, any reccomendations, incl size of tip to use appreciated Zen
