Hi D!
I just read your response and correct me if I'm wrong here but, did you write that the root pass for the NYSDOT test is to be deposited using E-6010, 5/32" Diameter? I ask this because, that is incorrect!!!
According to the NY State Steel Construction Manual, For SMAW the filler metal is 5/32" dia., E-7018 only! Think about it! Why would you or anyone in their right mind which includes you, want to deposit an E-6010 root pass on a 3/8"X3"X5" Backing Plate that has been positioned so that the center line of the backing plate is dead center of the 1/4" Root opening or gap, and is tacked to the back of two 1" plates with a 45 degree included angle & 1/4" root opening???
Joe Kane has a handout on this test, and if you ask him nicely enough (Just Kidding Joe ;)), he might just send you a copy that has alot more info besides the little bit that I've posted ;) Since I did'nt get permission from Joe as to whether or not I could share the handout with you, I'm not going to attach it here out of respect for Joe. :) If he says it's okay then, I'll be glad to share it with you in a New York MINUTE!!! :) :) :)
How about it Joe, Do I have your permission???
