Up Topic Welding Industry / Technical Discussions / MIG welding of C-276
- - By artzelda Date 08-21-2007 13:27
anyone have any experience welding C276 with the MIG process?
Parent - By pipewelder_1999 (****) Date 08-21-2007 16:26
We do it using GMAW Pulsed. Cleanliness and good operating equipment is essential. The weld is NOT fluid and only goes where the arc puts it.
Do you have some specific questions ?
Gerald
Parent - - By artzelda Date 08-21-2007 17:28
what electrodes and weld parameters are you using.
Parent - - By PhilThomas (**) Date 08-21-2007 19:29
<begin shameless self-promotion>
You might consider switching to flux cored wire.  Stoody has C276T-1 AP which welds very well in all positions.
It currently does not carry an AWS classification but the new FCAW spec was just issued (A5.34) and it will soon be classified as ENiCrMo4T1-4.
<end shameless self-promotion>
Parent - By js55 (*****) Date 08-21-2007 19:47
Phil's dead on. NiCrMo-4 is the matching chemistry for C-276. Although, for severe services sometimes higher alloy fillers are used to compensate for loss of corrosion resistance in weld metals. For example NiCrMo-7 (C4), or NiCrMo-10(C22), or if you really want to be safe NiCrMo-13 (Alloy 59) or 14(686CPT), though these last two are probably overkill, and I believe 10 is more popular than 7 when overalloying for 4.
Check with your the manufacturers for specific application and service advice.
