I'm not sure what two codes you are speaking of, but a 312 stainless steel and a 304 stainless steel can certainly be welded together. The 312 is a high alloyed consumable designed for welding C/Mn-steels, tool steels, spring steels, high temperature steels and other difficult to weld steels. The 312 is also suitable for welding dissimilar stainless steels, such as 312 to 304, and between stainless and carbon steels. The 312 has high tensile strength and wear resistance with excellent resistance to cracking. So, you should encounter no problems when welding these two metals together.
Chuck
Hello there Chuck, good to see you, hope all is well.
bryan, in regards to the two:
ASTM A312/A312M-06 Standard Specification for Seamless, Welded, and Heavily Cold Worked Austenitic Stainless Steel Pipes
ASTM A269-07 Standard Specification for Seamless and Welded Austenitic Stainless Steel Tubing for General Service
The signifigant difference is in tube vs pipe. I can't see there being a problem welding the two together.
I am assuming your welding an instrumentation line to a service pipe?
Regards,
Gerald
